Can someone identify what radiator this might be.
Seems my temp sensors are bad. Fans not coming on when engine temp reaches 200F, yet when I jump the wiring, they work fine.
Are aftermarket temp switches avaialbe? I am guessing I will need to drain the radiator to install them
Here are some pics
  • IMG_6605_72_pantera_radiator_LR
Here are some pics
Is there a relay used to turn on the fans or are the fans' negative leads wired directly to the sensor(s)? If it's there's a relay, I would check them first.
I am not sure how to tell. What do I look for?
If you can see a seam or a division in the passenger side inlet tank of the radiator, then it could be a three pass. It could also be a single pass, which may have been done by taking that baffle out of the inlet side tank and moving the outlet to the upper left side. I had one that looked exactly like that in my car when I bought the car in 1977. From the pictures this looks like a stock radiator that was modified.
