Hi All,
Last spring I replaced my steering rack with a rebuilt one when my front right suspension was making a loud knocking sound. Since then, I had to move and didn't get any driving in outside of getting the pantera aligned. Now that she is on the road, I am hearing knocking again from the front right. I jacked the front end up, grabbed the right front tire and checked to see if the wheel bearing was bad and it seemed fine. Any other areas I should look at?
Thank you,
Khan
...I Concur with the Coolant Pipe hitting the Front Anti-Sway Bar!! I heard it everytime I backed out of My Driveway or hit a Bump or Pothole! I did the same, wrapped the BAR, at the Contact Point, with the 'Pipe Insulation'. But I used 3 Nylon 'Wire Bundle Ties', One on Each End, One in the Middle! Havn't Heard the 'Clunk' Since, Perfect!...
