Should I try and remove it and replace it with the new robertshaw kit ?
Any idea how to remove it if in fact it is in there?
quote:Originally posted by 4V & Proud:
yes that is the brass restrictor in the pics, why would you want to remove it?
all you need is the correct thermostat which should be easy to find in Aus
quote:Originally posted by JFB #05177:
what a coincidance!
I was just wondering about how the restrictor plate is installed.
would it be possible to get a measurement from the flange where the thermostat rest down to the plate.
