Reassembling my doors after completing the body. Cleaned all the internals, repainted everything, machined and installed Taurus (Ford) window motors, etc. The passenger side door was a b@#ch, but it’s done. The driver side is KILLING me. I cannot, for the life of me, get the GD front 1/4 window to seat far enough forward to allow for the thin retaining pillar screw holes to line up (or to allow for the power window to come up fully). I have new rubbers, and have even sanded them thinner to match the old rotting ones I removed. I know it should fit, it came out of the damn spot after all. Anyone else been in this situation and have a suggestion (tried WD40, thinning rubbers).
Those quarter windows were one of my major headaches reassembling 2511. I feel your pain.
like you, I trimmed a bunch of the gasket that would not be visible and hopefully that made things a little easier
I taped everything together with duct tape. Gently hit a rubber mallet on a piece of wood that fit snugly into the window channel.
also drilled a hole to allow a Phillips screwdriver to serve as a prybar.
hope these help you out.
Thank you. I set back out after the game ended and gave it another try. I trimmed down the gasket a bit further, mostly on the sides this time to allow it to fit deeper into the door. With a little help from one of my boys I managed to get both holes to match up. Now I just need to see if the window (once all the guts are reinstalled) rolls up w/o too much resistance.
I always use soap ,( household soap for dishes) this will helps better than WD 40 , and slide de window horizontal .
Mount rubber 1/2 thick into the frame , and the glass 1/2 thick into the rubber on the vertical frame rail, and than hammered this directly on the glass forward.
And when the glass is on it's place mount the vertical rail , always scary to get scratches on the door and rail trim.
the trim on the top of the door has a small space to fit the horicontal rail
Use a lot household soap for dish , to soak the rubber more greasier than WD40
Have done several, never a problem .
Simon
