Originally posted by Steeler:
I may seem a dumb question, but how do I remove the Tach? I can't get my hand up to the back, to get to the fixing nuts. Frowner
Sorry to say, but you might need to find someone with smaller hands. Try taking the driver's seat out. It will give you some extra room to get your body and arm in a better position.
Steeler,
I recently installed one of those kits in a friend's Pantera. I used long (12") needle nose pliers. I was able to reach the connector on the back of the tach, so I didn't have to remove the tach.
BTW, that kit is really nice. If the engine dies (like during a cold start with no choke), you don't have to cycle the key....you just push the start button. Pretty cool.
John
Well brothers and sisters, I feel your pains.
The dual pod is a little easier to work with, the single pod is another story altogether. In fact getting the tach and speedo out is actually the easier part with the single pod. Getting them tightened back in is a different story.
I have found that to reinstall, if you install wing nuts on the studs, you can rotate them by their wings with a long screw driver.
The frustrating thing is that you can see everything from beneath the dash but you can't touch the original thumb screws with your hands and get a grip on them.
For installing that one new wire to the back of the tach for the P-E push button start, you may want to install a terminal screw on the new dual tab on the tach to insure it does not disconnect itself after reinstall. Been there done that.
The speedo goes back in first. Tighten it up via the tach hole, then the tach goes in since it has a little more room from under the dash and no duct to deal with.
You can get the wingnuts from Home Depot. They happen to stock them in stainless. Strange, but true.
