I have been working on a "Hot Box" to go along with the inertia based auto cancel turn signal and light controller I make. The set up has the headlight relay, the bright relay and 2 additional supplemental relays with an extra 3-5amp tap for radio and fuel injection memory.
The circuit is not ready for prime time yet. I have gotten the circuit where the supplemental relays can support about 20 amps continuous but a sustained 30 amps still has too much heat rise. There is a lot of added copper in a circuit to make it do work at these amps.
One thing I learned is that a 30amp circuit breakers get hotter then I realized and that I am comfortable with when a sustained 30 amp load is put on it. Intermentant loads are no problem.
I am looking at restructuring what I am doing to use 75 am solid state relays to find a comfortable level at a sustained 30 amps.
There are also a few fans out right now which have two circuits for high and low and they use 2 relays; one for each circuit. If you put 2 relays on a single circuit and one relay does not engage then you overload the other.
The light circuit and the relay circuit is my entire electrical circuit on my home built buggy:
