Can you give me the lengths of their shoulders. I'm planning on duplicating most of the fasteners in stainless.
On Wednesday, February 12, 2025 at 10:47:08 AM EST, Vincent <
kitchenguy@frontiernet.net> wrote:
Wow!!! I couldn't have asked for a better reply, thank you very much!!!
On Wednesday, February 12, 2025 at 10:17:25 AM EST, The De Tomaso Forums <
alerts@crowdstack.com> wrote:
[New Reply] Selector Housing Screws
| == To reply by email, write above this line. == |
New Reply By stevebuchanan
| Selector Housing ScrewsReply by stevebuchanan
These are factory bolts that been wire wheeled to remove rust and then sprayed with clear. They are steel 8.8, not stainless, and probably German. The two top bolts are 50mm long. The bottom right is 30mm. The lower middle and left are 25mm. The photo below shows they all extend roughly the same amount.
This post contains 2 images.
[ View Reply ]
You received this based on your notification settings. You can adjust your settings or unsubscribe anytime.
