Kevin I can volunteer for the test pilot duties if you need!
Jeff
Holy Cow Kevin. That baby looks sweet!
Kevin,
Car looks great! I recall running alongside your car at Riverside in 1989. The body had already been modified at that point so the conversion was done sometime before that.
The removable front/rear body clips are nice. My own GT-5 has a similar arrangement, and it really simplifies access:
If you ever want to change to a GT-5 style body, I have all the molds and can have more clips made. Or you can have an assortment and change them as the mood dictates :-)
Hope to see you on the track soon!
Dave
Dave
Yes Dave, the car did run at riverside. I believe that is where it hit the wall and then had the body modified.I also like the Gt-5 body style.
Very Cool!
quote:Originally posted by Rapid:
I think this has calipers and rotors from an older lincoln
67 Big Ford/Tbird/Lincoln. For all intents and purposes the same front brakes as the 67 Shelby Trans-Am Mustangs, the coupes.
The rotor bolts up to the Pantera hub. The only issue I see with them is that they have a US 5"-ish bolt to bolt spacing and the Girlings are 3" as most Euro brakes are. (3.3" -ish)
The Rear of the Pantera is strange. 2.4"ish. The 65-7 Mustang front calipers will fit with elongating the mounting holes. You can use the stock Pantera rear rotor or change it to the vented 65 Mustang front rotor, if you can find some? Those have been discontinued.
They are a massive setup. It would be great if they were available in aluminum (but aren't). Similar in weight to the big iron Girlings the Gp3 & 4 cars had installed on the race Panteras.
So you need to make adapters for them. Not a big deal at all.
If you aren't going to use them,
I have these on my Shelby. I'm thinking this would not be a bad solution for my Pantera?
Would you happen to know if an 8"x 15" Campi will fit over that assembly?
Really nice shocks. I'm envious.
Sign In To Reply
