And another:
Excuse the small pics but I cannot post images here anymore unless they are under 600 pixels wide!! Who knows why, George can't understand it.
quote:Originally posted by garth66:
Halibrands
I think this is #1889 owned by Ron Mccall?
That is just the style/wheels I want on my car!
Anybody have more info on these specific wheels? Brand/backspace etc?
Been looking thru the forum but cannot find the answer
What was the widest front and rear rim size that came stock on the 71 to 74 Pantera's
All Ford spec Panteras were 15" x 7" front, 15" x 8" rear.
The GTS in Europe had 15" x 8" front, 15" x 10" rear
-G
I have seen a few wheels that are stock looking campys that are 10" front and 14" rears, what are they from?
Malow,Please post a picture of the wheels you are asking about. Thanks
The only stock Campi's I know of that wide are the 10 spoke ones that came on GP4, GT5 & GT5S cars (i.e. widebody Pantera's) They are typically 10" front and 13" rear, although there are some 14" wide rears around, but those are quite rare as they are GP4 wheels. If you want the wide Campi's be prepared to shell out some $$, the last full set I saw sell, was for $7K, then you've also got the challenge to find 15" diameter tires for them.
Is there any source for Minilites (10x15) please ?
regards
Philippe
regards
Philippe
My new Forgeline centerlocks:
Great looking wheels, does Forgeline supply the hub converters too?
Indeed they do. It's a nice set up.
Hi everybody
Can anyone advise the Pantera wheel PCD so that I can order some wheels?
Thanks
Thanks
PCD = 5 x 114.3
Center Bore = 62mm
Center Bore = 62mm
quote:Originally posted by David_Nunn:
PCD = 5 x 114.3
Center Bore = 62mm
Many thanks
This is my custom wheel. 14*15" rear and 10*15" front.
Z
Z
WOuld you mind posting a few more pics of the 17" Billet Specialties wheels?
Asanti Wheels
Up Close...
Asantis look great, nice lip!
My wheels are ROTA GTRs and they can be bought from http://www.rotaaustralia.com.au/ . Price was AUD $1555 for all four. In the USA I am sure they are much cheaper.
The tires I bought from Albion Motorsport http://www.albionmotorsport.com.au/ and total was around $1880. Again I am sure they are much cheaper in the USA.
Fronts are 5x114.3, 17x9" with +25 offset(backspace 5.5"). Tires are Toyo Proxes R888 235x40x17.
Rears are 5x114.3, 18x12" with +20 offset (backspace 6.75"). Tires are Toyo Proxes R888 335x30x18.
My rotors and brakes are stock 72 and the body is also stock.
The fronts scrub on the inner fender well when at full lock both sides. Also has caught the right side outer fender lip and bent it out slightly. Ideally the front should be a 35 series and not the 40 series that I have which make the tires slightly more round. Apparently proxes in 235 width are not available in 35 series. Maybe going to a 225 width or a 35 series would solve the scrubbing.
For the rear wheels to fit I had to slightly bend the rear brake lines out of the way of the rim on the inner. This was easy because the brake lines were non stock and Australian compliant. I have had no issues with the rear scrubbing.
Also the centre caps that come with the wheels would not fit as the center hub was in the way. I made them myself out of 63mm exhaust pipe which I capped off with some sheet metal. It was then powder coated silver and I am currently having some T emblems printed in vinyl for the center. I also had to use a die grinder to open up the center on the wheel and then I trumpeted(peened) the inner of the center cap to keep it from coming free at speed.
After fitting the new wheels and tires I found that it sat too high and the gap in the rear tire well too large. So I ended up buying adjustable coil overs from one of the vendors. I found that the rear spring set I got are not really low enough. Another thing I don't like is that when the car is jacked up the springs do not hold in place but that's a whole other story.
These are my wheels made by a company in CA> called "True forged" They are 3 piece wheels in polished aluminum. 18x9 front and 19x12 rear they are wearing Nitto NT-05 235x40 R18"s 9.57" wide and 335x30 ZR19 13.31" wide
Brembo 4 piston calipers coleman rotors and custom billet hats
ZR1 - Those Asanti wheels really complement your car well. Thematic cohesion!
new and old
old wheels
Etoile 455 17"
Forgestar F14 in gunmetal
17x9 w/245's and 18x12 w/335's
Forgestar F14's will make you a custom offset wheel and supply hub centering rings. I went with 25mm offset f/r. The wheels are the least expensive option I've found to get the max tire sizes to fit on a narrow body car short of buying used. Thru Jurrian at ModBargains the wheels were $1500 and they took 4 weeks to get.
I think they look great on your car. Very reasonable price
The Reaper (Guest)
Those look great, and the price is just as good as their looks.
On the topic of inexpensive wheels I have a couple to add to the list with the Forgestar F14 wheels. I've been looking at ET Wheels, two specific retro models, the LT-III which looks like a mini-lite, and the AC-III which looks like a Cobra wheel. I am also considering the Enkei RPF1 wheels mentioned in the forums a few months ago. They are all inexpensive, and available in sizes recommended by Pantera International. I'm planning to go with a tire combination recommended in Pantera International's tire/wheel chart attached below. I haven't purchased any wheels yet, probably not until next year, so no pics.
Mistersolo,
I like the look of your wheels - especially the rears. Nice dish look. Great price too. Almost makes me think I should buy a set and sell my current wheels to my buddy who keeps hounding me for mine.
Devin
Devin
Sign In To Reply
