My sump plug is leaking, the threads are shot, can I take off the sump / oil pan without removing the engine.
Also, I made a mistake and fitted one rear wheel
to the front axle, I found out when the noise started, the inside of the wheel rim is scored all the way around!
I thought you could fit the rears to the front if you were lucky enough to find some 10 inch rears.
I have seen many of the 8" wheels installed on the front of the car. My original 8" rears were moved to the front.
I have no clearance issues. I do not require spacers in the front. They just bolt right on with no clearance issues.
This is the first I've heard of needing a spacer.
On other vehicles occasionally I have seen that the steel fluid tubing that crosses over from front to rear needs to be slightly bent so as not to rub on the inside of the wheel.
You need to determine exactly what is rubbing.
I'm not sure that the lug studs are long enough to enable the SAFE use of a 5mm spacer either. I would verify how much thread is left when you do that.
On race cars longer studs are usually installed. 1/2" of threads is not enough. What the factory provided stock on the car should be considered the MINIMUM.
Originally posted by Simon:
you need use a flat spacer 5 mm thick
Simon
Whats the reason for the wide spacer please Simon?
I found out that the rims have different castings , I have sometimes the same problem whit the 10" from the GT5 andGT5-S
5 mm spacers give no problem on the studs and the rims are still hub center mounted.
But to be sure, check also the tubing and bleed valve as PanteraDoug is suggest.
Simon
Peter, look VERY closely at the scored wheel. Campagnolo magnesium castings are only about 3/16" thick at the point where a caliper might touch. You'll have to decide if the scratch makes that wheel too dangerous to use. If its an aluminum wheel, they're typically not too expensive to eplace, but Campys are pricy! Spun- aluminum 3-piece racing wheels typically crack circumferentially about where the scratch is....
