Dear Fuzz,
I have had very good luck with custom Holley carbs built by Bob Oliver of Competition Carbs in Reno, Nevada.
You tell him what you want (650, 750, vac secondaries, double-pumper,etc). He will ask you for some specific parameters of your engine and your transmission and you intended use.
You will pay him about $1000. He will send you a carb that when placed on the engine for dyno testing is usually within one jet size of being optimal for your engine.
All of my custom carbs have been markedly better than off the shelf carbs that required constant fiddling and provided chronic disappointment.
Warmest regards, Chuck Engles
