webbers1972 Pantera, Restored. How do I put pic on here?
I cannot find my Tach wire on my 1972 Pantera. My wire color are older and are a different color code than a new car, Right? Does the Wire come from Under the Floor? I see no bl/bK WIRE. Does it come from a White plug? Hmmm.
There's a blue AND a blue / black that connect to the same pin in the nylon connector. The blue goes to the distributor, and the blue / black goes to the tach.
Note that in the pic, the blue / black wire has been cut.
