Such a cool project! Fantastic metalwork!
Pretty sure that's an aftermarket crapsman, it looks like that car has been in a serious side impact. Hopefully you were aware it had been in an accident when you purchased it, finding that kind of stuff out the hard way is disheartening.
clayt: Do you have any before pictures? What is that yellow crap that looks like wax?
Ogren, on Anders Hellburg's GR-3 website (www.scuderiadetomso.se) in Sweden is a copy of most of the GR-3/4 parts homologated for the real racers. One thing is an illustration of extended mounting lugs on the frame for the front lower a-arms. The actual part is no longer available but the photo shows the factory preferred lower mounting holes are roughly one bolt diameter lower than stock. This changes the front instant-center and alters the handling. Passenger car mount lugs are too short to extend the bolt hole enough so welding is needed, but the stock holes are unaltered if you prefer that alignment. Something to consider, seeing all the work you've done already.
The cutout behind the front wheel looks great!!
Wow, This is an incredible build.
Based on my experience the front airdam height is set to low. Obviously impractical for the street. However, it is also to low for the track. Inevitably, you will have an off course excursion or catch a curb or turtle on an apex. Hweck, it will require significant ramping to get in and out of your trailer w/o damage. Make certain it is designed to brake away with minimal body damage and have them fabricate 3 additional replacements while they are at it. As a fellow racer offering advice, you'll need them.
Now if you intention is to park it in your collection, no worries.
Stunning work
JT
Awesome
Great looking shop, as well as a great looking Pantera!
Why did you replace the Graziano with the Ricardo? The Ricardo’s seem to have maintenance and part’s availability issues. For that matter, why not just keep the ZF?
Just curious!
Also, I like your rear lower control arms and the way they attach to the uprights. Solves all the lower shaft issues.
