Looking to put on a Robertshaw 333 thermostat. The existing old thermostat has the gasket on top of the thermostat, but the Pantera technical information folder says the gasket should go on the block opening before the thermostat is installed. this would mean the gasket would be between the block and the thermostat.
Looking for some guidance on which way is correct. Thanks!
