I need a couple of Universal joints for my drive shaft, I want to get them here in England, can someone let me know the designation number of the UJ, or let me have the correct size please
regards Peter
quote:Originally posted by JFB #05177:
please do report back
from what I have read/found online,
the Spicer replacement driveshafts would use the imperial size Spicer 3-2-159 yoke with dimensions to accept the 1.187" (30,2mm) X 4.187" (106,3mm) UJs
where the original driveshaft yoke was the 32mm X 106mm UJs
the discription of your "new" UJ appears just to be wrong A/B dimesnion
so the extra lenght of the cross was due to the cups not being pressed together.
too late now, but working with similair assemblies, removing the grease zerk to allow air to escape could have helped when installing. (but there would have been the "spring" of the rubber seals also)
can you share the make and part # of the ones you installed?
