I am freshening up a set of heads recently acquired that had been sitting for several years. However, previous owner thought them to be bolt on ready. Upon dis-assembly, found there to be no hardened spacers under the valve springs. Many years ago, I assembled a Cleveland head w/o shims and the rotating valve springs cut grooves in the cast iron seats. I have always cut the seats deep enough for a shim since that experience. However, perhaps the cutting issue was my failure to debur the springs' leading edge.
What is the consensus among engine builders - Shims or no shims, assuming proper spring height w/o them?
I'll probably shim these anyway as spring height is inconsistent, yet around 1.90""
