The VIN number is on a plate attached to the dashboard in the upper left side. All the info is also permanently stamped into the top of the toe box under the front hood. Both areas may have been reupholstered over the VIN info, but unless the areas have been actually cut away for some illegal reason, the stamped info is still there. The engine # etc is on another plate rivetted to the left rear inner fender panel and matches the stamped # above the l. side of the bellhousing.
