i would like to run a high flow water pump, my question is, if i run a pump without the bypass port , do i still need to run a thermostat?, i am installing an entire system from HALL, phoenix radiator, stainless pipes, mariah fans, stainless water bottles, and gates green stripe hoses, just want make sure i dont have any cooling issues also,...which pumps are available and work well for the pantera?,........THANX........DAVE
