Actually if you have the water pump off ( which I just did) and look into the upper opening on the passenger side of the block you will see that the opening for the sensor is in fact into the recirulation path below the thermostat to the pump. The tap in the pump is only inches away in the same water flow so will give the same readings. I use the tap in the pump for the sensor for my fuel injection and it gives the same readings as the guage in the block when they are compared.
Forest
Originally posted by gromo:
Hello
I'm trying to place the water temp sender on the block but didn't find exactly where to place it? Didn't find any plug where I can put the sender ?
Looking from the inside of the car , is it placed left or right of the thermostat ? Near the carb ? Left or right or front or rear of the distrib ? If someone has some pics or advice avalaible that would be great..
Thanks in advance
Thierry
