What size tires are you guys running up front on 15" rims 8" wide?.. Has anyone run 295/40/15'S??.. Did they rub?.. Thanks for any help or advice...
quote:Originally posted by Cowboy from Hell:
The tire that the factory installed on the 15" x 8" wheel is 225/50R15. That's the tire that was installed by the factory on the GTS Panteras with the 15 x 8 Campys in the front. The widest tire you can fit in a narrow body wheel well with "minimal" rubbing is a 245 section, but those should be mounted on a 9" wide wheel. A 295 section tire will rub too much. But just as importantly, it is not a good fit on the 8" wide wheel.
A rule of thumb, the width of a tire's tread should never exceed the width of the wheel it is mounted on.
cowboy from hell
cowboy from hell
quote:I had 295's on my 8" rears and they looked odd and were probably quite unsafe too.
quote:Originally posted by garth66:
I'm running 225/50VR15's on the front of my narrow body pre-L and 295/50HR15's on the back. But I think you have a flared car, right?
quote:Originally posted by Mark Charlton:
...Most of the 17" x 11" Campy clones are shod with 315 or 335 width tires (which both look right to me). But 11" is only 279.4mm...
quote:Sorry for the hijack, but what size are your front/rear wheels? I'm assuming 8" front...?
quote:Originally posted by garth66:quote:Sorry for the hijack, but what size are your front/rear wheels? I'm assuming 8" front...?
Do you want to know what size my front/rear wheels are, or PLT-1's front/rear wheel size?
Mine are stock Campy 7's and 8's. I'm still looking for one more good 8" Campy, then I'll change the fronts to 8" wide Campys.
