Hey. Anything special about those wheel studs. I have one that needs to be replaced (while I am putting on the new rotors) and looked all over the NAPA book for no matches. Any ideas?
Stock Rotors or aftermarket? Stock has a shoulder between the knurling and the head for the rotor. Stock rotors mount inboard of the hub. If you have aftermerket rotors that mount outboard of the hub, you need that shoulder between the knurling and the thread. Other than that, 12mm X 1.5 pitch and the proper length should be all you need.
Jim.......They are stock, and I'm replacing with the GTS vented I picked up earlier this year. (I have one on the passenger side that previously had a few threads stripped off and I've wanted to replace if possible).
I was never able to find wheel studs in typical auto parts stores. I eventually picked up some spares. There was also a guy (in Canada ?) that was offering some real cheap too.
Jim.......hey, sorry for the late reply. I actually ordered one (yep just one) this morning, but do appreciate the offer. BTW, my e-mail is rittwege@bellsouth.net.
