Just called Hall Pantera to order a new speedo cable. It ticks, especially in warm weather. Thought I would replace the speedo cable but I was asked if I have a ZF-1 or ZF-2 transaxle. How can I tell the difference? 1972 Pre-L #2458
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
The speedo cable is more dependent on the type of speedo drive you have is it square or a spade? You should have a -2 transaxle with side mounts, not a rear mount.
