Does anyone know which model Wilwood brakes fit the Pantera? I will be retaining the original Campy wheels, so need to fit behind them...
Thanks in advance
Jim
quote:Originally posted by ehpantera:
Jim,
I purchased my Wlwood brakes from Dennis at Pantera Performance. They will fit under the 15" wheels with a little grinding on the caliper corners. Dennis was very helpful in making sure I got the proper setup. For a long time I planned on getting the parts and make the brackets myself. I don't think it would have been worth it. The installation was very easy. I would highly recommend that you get the rear rotors mounted on outside hats at the minimum. It makes changing rotors very easy. You might as well rebuild the rear uprights while you have it apart.
I am very pleased with the Wilwood system.
Mark
quote:Originally posted by mooso:
I think friend Coz is showing off his long studs again.
Mooso
