Anyone ever used one of these? I have rebuilt and then replaced the rear calipers, they work as they should for braking, but they hang up when the parking brake is applied all of the parts, cables, springs etc. were new and well lubed.
How do the Willwood units attach? I looked at the dedicated ones for the Pantera and they are about 600 bucks. The Willwood are $60 per side. They have about 4 or 5 models which one(s) did you use.
thanks,
Gary #06984
  • wilwood
Yes I have used the Wilwood mechanical caliper & all I can say is I would not even use them on a Go Kart.
They do not work, simply not enough leverage & too small a brake pad area.
This is a big issue in regards to suitable hand brake calipers, theres very little on the market.
Most that are available have tiny brake pads.
When I installed the Wilwood mechanical calipers I replaced the original cables with push/pull morse type cables.
Also extended the lever arm on the caliper to 150mm long to increase leverage.
Still does not really work as the pads are way too small & leverage is still really lacking.
I'm going to try BMW hand brake calipers from the rear of an 05' Mini.
(I have 4 piston Wilwoods on the rear for stopping).
When it comes to the handbrake I take advice from my fellow Brits in the UK because to pass an MOT test the handbrake has to hold the car against a rolling road.
IMO good handbrake calipers are Brembo 2DO mechanicals, Hispec or Preciosn Brake. None are anywhere near as cheap as the spot calipers, but I guess it depends what you want your handbrake to do.
I'm not familiar with the new Mini handbrake, the Dodge Viper has a mechanical handbrake but again they don't usually come cheap.
