Have been looking around for some info on this setup, but I can't find any.
quote:Originally posted by Panterror:
Does it also have a different master cylinder than stock? Needs twice the volume of brake fluid to move two rear calipers per side. Not sure why you need it on the rear. More unsprung weight.
K
quote:Originally posted by larryw:
I thought about this too.
If you were to just eliminate the stock proportioning valve, which I understand limits pressure to the front brakes, as so many people do, it seems like a good idea to add the additional braking capacity in the rear to balance things out.
The reason why I installed an adjustable proportioning valve was to balance the system. I didn't want the rear brakes locking up before the front ones. The front brakes receive full pressure and the rear ones don't.
Regarding the weight, I weighed a rear caliper last winter when I rebuilt mine and I think it was only about 6 or 7 pounds.
It seems worth a try. At least until I can afford the 17" wheel upgrade that will allow the fitting of larger rotors and calipers.
