Originally posted by mike the snake:
I'm setting myself up for screens, but also ordered a motorcycle filter like in the pic to see if it'll fit. The rubber needs to stretch a little, I need to see if it'll fit, and then I might consider running separate filters like those.
My stacks might be too close to each other though. I'll know this week. It was worth $20 to order one filter to see if it'll work.
You need to slot the rings on the filter to get the stacks in.
These K&N's were $40 each through a WD. You could get filters that look like K&N's cheaper I suppose?
Looking at my stacks I'd say the K&N probably will not fit.
I think you need to get two filters to see if they will clear each other to be sure.
The filters in my picture are on the original Weber stacks which are much smaller at the edge of the stacks rims then the spun aluminum stacks.
I saw a Hilborn Injection set up on a BB Chevy once that had one stack tall and one short pattern, so that the mouths of the bells would clear each other.
I don't know how it ran. Just saw the setup.
