Two Sets of FIAMM Horns... (I'll test them before I ship them)...
Set #1:  Italian FIAMM CTR Horns (High & Low) - Crack on the end of the High note trumpet (see picture) - $50 (plus shipping)
Set #2:  Italian FIAMM Horns (painted) for Pantera with FoMoCo logo stamped on both mounting brackets (High & Low) - $80 (plus shipping)
FIAMM_CTS_Horns [Large)FIAMM_FoMoCo_Horns [1) (Large)FIAMM_FoMoCo_Horns [2) (Large)FIAMM_FoMoCo_Horns [3) (Large)
Images (4)
  • FIAMM_CTS_Horns (Large)
  • FIAMM_FoMoCo_Horns (1) (Large)
  • FIAMM_FoMoCo_Horns (2) (Large)
  • FIAMM_FoMoCo_Horns (3) (Large)
More stuff bubbling to the surface...  Spare Tire Hold Down Screws (3x), Hood Prop Rods (2x), Stock C&C Decklid struts, Idler Pulley bearing holder assemblies (3x), Unknown valence panel set (Right & Left), seat belt belts & parts, used windshield gasket & 10-12' of new gasket material.
SOLD - Powder Coated Black attachment fixtures for Gas Tank Shield - $20 (plus shipping).  Note:  the pictures don't show the fine quality of the black finish.
Seat Rails - complete set, plus knobs and hardware - $300
Mystery Valence Panels...  If anyone knows what the R&L Valence panels are, post up here!
Thanks -
Gas_Tank_Shield_Brackets [2) (Large)Seat_Rails [Large)
Valence_Panel_Set_Unknown [1) (Large)
Images (3)
  • Gas_Tank_Shield_Brackets (2) (Large)
  • Seat_Rails (Large)
  • Valence_Panel_Set_Unknown (1) (Large)
How much for wiper grill,decklid shocks,prop rod,gas tank brackets. Thanks, mike
Sent from my iPhone
On Sep 13, 2024, at 9:12 PM, The De Tomaso Forums <alerts@crowdstack.com> wrote:
== To reply by email, write above this line. ==
New Reply By rockyrocky
More stuff bubbling to the surface...  Wiper Grill (Hole on the large side of the grill), Spare Tire Hold Down Screws (3x), Hood Prop Rods (3x), Stock C&C Decklid struts, Idler Pulley bearing holder assemblies (3x), Unknown valence panel set (Right & Left), seat belt belts & parts, used windshield gasket & 10-12' of new gasket material.
Thanks -
Gas_Tank_Shield_Brackets [1) [Large)Gas_Tank_Shield_Brackets [2) [Large)Seat_Rails [Large)Valence_Panel_Set_Unknown [1) [Large)Valence_Panel_Set_Unknown [2) [Large)Valence_Panel_Set_Unknown [3) [Large)
This post contains 6 images.
[ View Reply ]
You received this based on your notification settings. You can adjust your settings or unsubscribe anytime.
Windshield Gasket (still soft) and about 10-12' of new, straight gasket material $80 (plus shipping)...  It's in two pieces, an upper corner (and half) and a lower corner (and half).
If you buy it, I'll throw in this shorter (about 4') length of smaller material - you can line a part of the decklid opening?
Windscreen_Gaskets [2)
Windscreen_Gaskets [1)
Images (2)
  • Windscreen_Gaskets (1)
  • Windscreen_Gaskets (2)
351 Cleveland Builder’s Kit
Build yourself an accurate replica of a ’71 Pantera Motor, or a fire breathing stroker with this set of great condition parts!  The majority of the parts to build your engine are included for one low price!
Parts are for pickup in the Tucson, Arizona area...  Due to the volume / weight of all this, it's too much to ship.  MAYBE arrangements could be made to get them to SoCal at additional cost.
BASIC REQUIRED PARTS:
351 Cleveland Block: 2 Bolt Main, Bored .030, honed.  Needs a wash and minor cleanup.  New freeze plugs and ail gallery plugs.  Looks like new cam bearings.  Mains are 2.950”
Crank (4MA): Good condition - needs minor cleanup. 2.748” Mains, 1.310”
Heads: Date matched D1AE GA High Compression (quench) heads.  Valves (Ford) and dual springs installed, with keepers.
Intake: Choice of Edelbrock Performer LB 351-4V intake (aluminum), or one of two Ford cast iron “period correct” spread-bore manifolds (details on request)
Valve Covers:  Chromed stock Ford valve covers.  A series of alternative options (DeTomaso, Ford, Ford Motorsport) available for additional charge.
Oil Pan:  Beautiful stock Ford blue oil pan.  Looks brand new.
Engine Stand:  Harbor Freight stand included with block
ADDITIONAL ITEMS (Additional Cost):
  • Ford 400 2V Air Cleaner (top & bottom) – needs a different sticker
  • Flywheel G5AE-E  (164 tooth)
  • Pantera dipstick tube assembly and dipstick
  • NOS “Antler Ears” original headers – in Ford Boxes!
  • Pantera Water Pump and back plate
  • Balancer: Choice of D1ZE-6316-AB or DOAE-6316A1
  • Pantera Air Conditioning Compressor Bracket and Idler Assembly
  • Powdercoated 1 groove water pump pulley (black) – like new
  • Powdercoated 2 groove crank pulley (grey) – like new
  • Alternator Adjuster Bracket (like new)
  • Timing Pointer
  • Rear engine intermediate plate
  • Chrome Fuel Pump – updated with AN Fittings (in/out)
  • Coffee Can with misc. bolts and parts for build
All parts in good or very good condition, but some need cleanup.  You won’t find a better basic setup for an engine build.  PM me (Rocky) for pictures and more information.
