Hello everyone,
This year we started an extensive restoration of Mangusta number 834.
Now running I come upon a small mystery, hopefully for you guys this is a problem that will have occurred before.
There is no way I can find the correct diaphragms for the bonaldi brake booster.
Has anyone found parts for this, or is the only option another brake booster?
any other bonaldi is basically too big for the cramped mangusta dash and pedal placement.
I would like to let you know that after reading several treads I very much admire how the Detomaso community provides each other with information and helps whenever possible.
Kind regards from the Netherlands,
Martijn
WhatsApp Image 2022-10-03 at 2.30.07 PM (2) WhatsApp Image 2022-10-03 at 2.30.08 PM (2)
WhatsApp Image 2022-11-29 at 9.57.09 AM (4)
Images (3)
  • WhatsApp Image 2022-10-03 at 2.30.07 PM (2)
  • WhatsApp Image 2022-10-03 at 2.30.08 PM (2)
  • WhatsApp Image 2022-11-29 at 9.57.09 AM (4)
You are retro-fitting power brakes? Mangusta's had non-powered breaks. Much easier to locate the Girling (non-power) booster. I don't have the info handy but I recall the unit was easy to find and not terribly expensive. Also, some of the brake lines are soft rubber, which I would imagine must to be converted to hardline if you go with power brakes. I would be a little surprised if that booster fit under the hood. I'll try to measure for you next time I'm in the garage.
Good luck!
Hate to be the bearer of true news......but the Mangusta very much DID come with power brakes!   Likely every last one of them did!
Booster is in the interior of the car, behind the instrument panel!   So much fun to get at..........!
If this was a Benditalia (Bendix Italy????)  piece, it could share parts with a similar Bendix boosters we see here?
Try a local booster rebuilder......but I presume you already have......they are rare fish to find these days!    There is one left here in San Jose........
POWER BRAKE EXCHANGE - 2870 Aiello Dr, San Jose, CA
Cheers!
Steve
SCIFI,
YES! That could indeed be a BIG source of your requirement for a BIGFOOT!!!
There should be a 13mm pipe of sorts in the front boot area (under the covers?) which connects to the under dash booster via rubber hose. From there the pipe runs into and along the inside wall of the center spine, exits with the water tubes and continues down the LH side of the rear lower frame structure, turning upwards at the rear of the engine aprox at the engine/bellhousing joining line.
It continues upwards perhaps a foot or so, which is where it is supposed to connect to a 3/8" -13mm ID rubber vacuum line which travels up and connects to the rear of the intake fitting (that should be there!).
There should be a check valve on the booster itself, and these are known to go bad.....effecting a vacuum leak to the engine......but these can be checked easy enuf......  Ping me back if you need more on that....
Note in pic below, black tube at bottom left frame member, curves upwards, thru red shop towel and is capped with a green cap just peeking out over the frame reinforcement on the shock tower.   You can also see where it snakes around to the front and into the spine tunnel.  At this point I believe there is a rubber hose joint of sorts there.   I had removed the pipe to paint it......so it is NOT one continual piece to the front of the car.
100_2778
Cheers!
Steve
  • 100_2778
