We tested out our brakes and shocks today.
Wow! We haven't taken the proportional valve out in the front yet and the car stops on a dime. With it out, the braking will be insane. We can lock up the backs on medium braking.
If anyone is interested in a VERY affordable brake kit that is superior to any other brake kit on the market, let us know. On our car, we have our 6 Piston kit all the way around with 14 inch vented and cross drilled rotors in the front and 13 inch vented and cross drilled rotors in the back. This kit will be perfect for 18 inch wheels and up.
We will be offering two kits. For you performance junkies out there, we will have our 6 piston kit mentioned above that has AMAZING stopping power... This is going to get you the best performance available at an unbelievable price. We will also be offering a more affordable kit that has 4 piston calipers all around.
And for those of you with smaller size wheels, we will have a build your own brake kit. You will be able to choose the rotors you want and the calipers you want.
As always, SACC Restorations will offer these kits at afforadable prices. While we aren't ready to release our final pricing yet, we can tell you that our 6 piston kit will be more affordable then our competitors 4 piston kit.
A nice feature of our kit as well is that our hats are mounted inboard of the hub, just like the OEM hats which gives you the advantage of not having to change your offset of your wheel.
Our Electronically Adjustable Shocks are also great. When it's in Comfort mode, it's soft, but stiff enough that the body roll isn't bad. It is a very comfortable ride.
Now once we get into Sport mode is where it starts to get fun. In Sport mode, you can do a tight corner and keep the car relatively level with absolutely no body roll whatsoever.
These shocks are one of the best investments on your Pantera that you can make.
We are still doing our raffle for a free headlight kit to the first 10 Shock Set buyers.
Purchase your Shocks Here
Here is a video of moderate braking from 60-0MPH.
http://youtu.be/b0gP1LSc6bI
