Good Afternoon,
I pulled the ZF in my 72 pre-L over the weekend to work on a clutch pressure issue.  I only have 4K miles on the McLeod setup that I purchased from PI.  All in all, it looked good but thought I would order a new throw-out bearing and clutch while I had it apart.
It appears they made a change to the clutch since I bought the last one 2 years ago.  I did order the clutch direct from Summit this time, but it is the same part number as the original one I bought from PI.
11" dual friction
McLeod Racing 260531 McLeod 500 Series Clutch Discs | Summit Racing
Anyone had experience with this new version?  I'm wondering if I should leave the old clutch installed or give the new one a go.  The ZF isn't that difficult to remove and install but don't want to do again if I don't have to.
New clutch on top and old one on the bottom.
Thanks,
John
#3590
  • mceclip0
Interesting response from McLeod.   It appears that I had a 100 series disc in the original kit I purchased, though the box said it was a 500 series.  The new clutch is a 500 series so I'm excited to see what the differences are.
The old disc is what we call a 100 series disc.  Link - https://www.mcleodracing.com/100-series-disc/p119
The new disc is a different disc, its listed under the 500 series.   Link - https://www.mcleodracing.com/500-series-disc/p121
You had mentioned that the original disc said 260531 on the label. Yet you received a 260131 disc which is actually a 100 series disc.
Now you purchase the same part number and actually get a 500 series disc as its supposed to be.
Thanks,
John
Marlin,
Thank you for your opinion.  I appreciate it!
I'm definitely not looking to drag race this car.   It has seen a couple of track days and will be on the street 99.9% of the time.
What do you think about the specs on the 100 series clutch disc?  I assume it is a more traditional clutch like you are describing?
I didn't have any clutch slippage issues before I removed it.
The HP on this engine is around 450HP.
Thanks!
John
