joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
As it appears to be only the mufflers and not headers, you will want to verify fitment with your existing headers. It looks like the flange is three bolt welded not a rotating slip ring, so tweaking them for level tips might be difficult.
Be careful when buying any aftermarket exhaust. The flanges may not align with your existing headers(factory or otherwise) and you will end up either sending them back or incur additional expense in having a shop cut and reweld to exit the exhaust pockets properly.
well my ANSAs GTS version - tips up - have also welded flanges...There is some play in setting them up in the Y axis/up down but rotation would be difficult..
but Joules is correct FITMENT, however inverter/electro welding is no more a difficulty these days..
