Good Afternoon,
I just received my new clutch MC from Wilkerson, part # 005-02B.  I have an early 72 pre-L car.
I noticed the trunk side lines up as it should, but the rod on the pedal side is at least 1.5" shorter than the original assembly.  Even if I take the longer fork from my original unit and put on the new part it seems the pedal travel will be too short.
I measure about 2.125 inches of travel best case with the fork screwed all the way out.
I assume this is the wrong part?
Thanks,
John
#2551
Images (2)
  • New Clutch MC vs. Original
  • Clutch pedal
