My beautiful Pantera is now 1 week old. I opted out of the purchase of another Pantera losing a big deposit due to the fact that that car had not been restored. The car I did buy has undergone a fully documented ground up restoration. However, the car is 'kermit green' in colour. The car does attract a lot of fuss, but, I question whether it is the car or the colour. Chances are a bit of both. Though the colour does grow on you, I always dreamed of owning a Black Pantera. I did show the car to a painter who claimed he had sprayed more Rolls Royces than I had hot dinners. He even tried to talk me out of spraying the car black on the grounds that the paintwork was so good and that it would be a crime to change something already perfect. There is a GT4 conversion on the way, but, has anyone got any moral reasoning on what I should do, bearing in mind this all boils down to budget?
There is no color code on a Pantera to indicate what the original color was.
The only indications you will get of it is from the overspray on the car.
Even if there is overspray who is to say if it is original overspray, that would just be someones opinion. It is possible to strip all original indications of the color.
There is no indication, or market trend that the original color on a Pantera makes the car more valuable, particularly in light of the fact that there is no factory paint code indicating the original color on the car.
Paint it what color makes you happy.
You really can't make the car more valuable with a particular color but you certainly can hurt it.
I do know the color green you speak of and it is not attractive on a Pantera to me.
Paint is only temporary. It won't last forever.
One really has to figure that if you get tens years out of the paint that is fine.
If one is of the school that a restored car has to have the original color to be restored, then don't forget that you must use the original paint system as well to be accurate.
For instance if one "restores" a '65 Corvette, then the painst system must be acrylic laquer. A 63 Cobra will be nitrocellulose, etc, etc.
If you know the original color was white...then that would be the color to repaint it, in my opinion. Any future buyer will be more willing to purchase a car that is the color the factory first painted it. As more Panteras get highly modified and changed around, the stock ones become scarce and more desirable, again, in my opinion. That's not to say highly modified cars are NOT in demand, just that there is a wider audience for stock type cars. I don't think the chemical makeup of the paint itself is important.
Original color White? How do you know? You might check under the carpets to see what color is there or under the headliner area.
Original colors will be more valuable in the long run and White has some very desirable characteristics: it hides imperfections, scuffs and dings very well; it hides waves in the metal very well; it is the easiest color to touch up should that ever be necessary; it is easy to match should you get in a little fender bender; it is not ticket bait; and white cars are cooler in the summer heat. Dark colors or metallics are difficult in any of these situations and they look dirty quicker.
It's okay to use modern base coat, clear coat paint. And in fact, a good layer of clearcoat can alleviate a lot of problems, scratches, nicks, chips, and dings because it can be wet sanded to get through the problem. When you wet sand the darker colors, it leaves a visible low spot in the paint, even though the low spot may only be microns deep. Of course, if you are absolutely sure that your car will never get any of these, then that is not an issue. %^)
In spite of all this, if the present paint is very high quality, just drive it and enjoy it. Quality rules. More people will comment on the quality of the paint job than on the color.
Jeff
6559
Originally posted by Deloreans and De Tomasos:
My vote is for black pearl...
yes black IS beautiful. everybody will own ONE black car in their life, but few ever own two, vey demanding color to maintain. it is a very classy color though, and at the same time mean and menacing.
Originally posted by JK:
...I thought we agreed white only belongs on appliances...
ROTFL
besides black, the other classy color is silver.....
  • 6018_left-rear
Originally posted by Mark Charlton:
Bulldog,
PLEASE post a pic of your car. Mine was originally lime green (close enough to Kermit, I guess) before it was painted white. I've never actually seen a Pantera in this colour and it was apparently fairly rare (I think I know why).
What do you think ??
Mark
  • Pan_PI
Jeff
6559
A lot of common sense there. Thanks !
Originally posted by bulldog:
Originally posted by shotgungrooms:
Lets see some photos of your new car Wink
Thanks for your interest.
That's the only lime green Pantera I've ever seen. I didn't know it existed.
I suppose one has to consider that these are '70s "mod" colors. Ford US was into "grabber colors" at the time.
It is most interesting to me that the car was never available in black. Regardless of the lack of it's practicalaty, I think it looks best in that color even today.
There are probably more black Porsche 911's then any other color also with the possible exception of metallic silver.
Bd, I think the green looks pretty good ! I think most people will agree...
What's REALLY important here is that you purchased the best Pantera within your budget. Later on if you tire of the color or being known as the guy with the lime green Pantera, you can always paint it.
Good luck.
BD, I paint cars for a living. If your paint is that perfect, I would not strip it, but paint over it. Todays paints are much better than 30 years ago. I just finished my car with single stage urethane. If you think the green is just too much, how about break it up with the hood and deck blacked out? I ran my car this way for about a year while I contemplated what to do next. It gives the car a 70's look. $7000 sounds like a lot for a paint over. if you strip it back to metal. There is no telling what is under the paint. Drive it a while and see if anything pops up or cracks back. If it is fresh paint., it should cure good anyway. Congradulations on your purchase. When I am asked to paint black, I steer my customer to a black sunrise metallic colour that looks pure black until you get real close then you ess the flash of the flake instead of the minor suface imperfections that regular black shows so well.
  • Dsc00698
[QUOTE]Originally posted by lastpushbutton:
The prevoius owner put a double coat of everything on. You can tell from one large stone chip the thickness of the paintwork. People have commented that if there is too much paint, it will have to be striped to the metal because paint over thick paint will eventually cause rippling.
How true is this? If this is the case an expensive bare metal respray is the cure.
BD,
that certainly isn't BRG is it?
In the states, 40 years ago, that color was called Grabber Green.
I'll lend my voice with the others who have advised you to "drive the car awhile". Don't rush into anything. If the car is an investment you plan to turn around for a profit, then repaint it in the oem color. If you plan to own the car awhile, then paint it the color you've always dreamed about.
your friend on the DTBB
Originally posted by george pence:
BD,
You always hit the nail on the head. Thanks.
BD,
I have had much the same dilema, having acquired a green Pantera in Nov last year. Mine is the later BRG type green and I have to admit the color does grow on you after a while. It has been repainted the origional color at some point, although there is a lot of crazing and it will need a repaint. That'll come after the addition of GT4 flares and I think the color will suit the wider GT4 stance...we'll see.
For me being a Brit, the BRG is growing on me. I had a Triumph Stag years ago in the same color. I'm relishing turning up at events in an original color car where the likelihood of having more than one other P car the same color is small.
Here's some of thoughts to mix it up a little on color choices;
A) The guys that steer you to red are mostly wanna be Ferrari guys Big Grin. Too many Ferrari's out there and even more 'uneducated' people who think you have a Ferrari..Take the confusion out of it, don't go red.
B) Black seems a popular choice at present; Anomolous to Kids names these things go in phases, be different.. buck the trend or start a new one!
C) Having owned two black Vette's in hot climate zones I swore I'd never have another black car, especially one that is renowned for being hot inside (I actually melted a portable CD player, left in a Vette during summer).
D)Black can be a 'Bitchen' color but a 'Bitch' to keep clean and looking the way it should.
D) Don't go white....you just can't find your white car in the snow Big Grin
If I ever did change color it would be to a dark blue, Panteras look good dressed in blue. But for now green it is....
Whiplash is the only dark blue car that I can remember and for me it isn't dark enough.
Anyone out there have a dark, dark, dark blue car or darker they can show?
My car is red with black highlights. I really hate red.
I had seen a light orange or tangerine car from Montreal awhile ago. I thought that was nice.
Mike Daily's car is a very dark red, almost maroon. It's pretty.
I wanna stay away from those "grabber colors". I thought that the nicest was the "competition orange".
I think dark colors look best on the Pantera.
