Most of the issues are caused by a mismatch of thermostats with the Cleveland or by using aftermarket water pumps like the Wieand that do not have the bypass hole drilled in them.
I did have issues with the Wieand pump initially since I did not know about the lack of the bypass hole.
The car temperatures would radically cycle from cold to very hot and seemingly take forever to get to a steady running temp?
I stayed with the Cleveland thermostat, the stock brass restrictor plate and drilled the bypass hole in the pump.
The temperature is now predictable, rises as it should on the gauge.
The product description says that "leakage" through the original thermostat seat is bad. I disagree. It is there to reduce thermal shock to the engine.
There has been much discussion of this subject here on this forum. This new block off plate is a relatively unknown item.
I'm not sure if it's a good idea on a Pantera with the as delivered cooling configuration?
Using it, you could be into re-inventing the wheel with the Pantera? Why do you need to do that?
Over heating issue reputations are really caused by the early cars, i.e., the '71s. By the time you get to the "L" cars, those issues were corrected.
If you feel that is hog wash and want to reinvent the car, have a good time, but it's not necessary.
A stock L will run in the Phoenix/Vegas heat with little issue at all.
With a 50/50 ant-freeze mix and a 16 pound system where the cap works, you are good to over 250 f of water temp before it boils over. 254 I think is what the chart shows? People seem to freak out when the car gets to 212 for some reason? It's supposed to. 220 would be a nice running water temp and 220 to 230 for oil is good. You have to get your oil over 212 to boil off the water contaminants. Cold oil will also cause more wear to your engine than 100,000 miles will AND it contribute to parasitic loss of horsepower internally in the engine. Race cars now use oil heaters to bring it up to operating temps.
Honestly, I'd be getting nervous around 240 water temp. That's where the car is getting hot.
If you do anything to the car, go with Halls brass radiator. It has a 50% greater cooling capacity and can be repaired vs. the aluminum radiators that when they hole through, and they will in a couple of years, are done, those you throw away because they are not repairable. They are usually rotted through the aluminum then. The aluminum radiator is not the way to go on this car. The ONLY advantage it has is weight savings.
Just my perspective. Others here have different opinions. Smiler
There is NO advantage to blocking off the original 'Warm-Up' Bypass Curcuit!
I agree with PanteraDoug.
The Engineers put it there for many reasons. One of them, precise control of the Cooled Coolant coming into the Engine, from the Radiator. At the proper, Sustained Temperature, Your Cleveland will 'Purr Like a Kitten'. Because the Temperature is Constantly Stabilized. Why do You think 'They' describe It as a '....Stat'. As In 'Static'.
We Machine the Copper Skirt and Install it Onto the Proper Robertshaw Thermostat. NOW the Correct Skirted Thermostat IS Available, Again, as a reproduction; in Numbers to cover the Orders of the Entire World.
Yes! Some 4.5 Million Cleveland Blocks were produced! I figure, perhaps, a Million have been Melted Down. So 'Bring It On'!
I offer You a Choice of 160F, 180F and 195F Degrees(Must Specify the Default is a 180F), While Supply of Thermostats, Last. Put Your Orders IN. $47.99 USA Shipping $5.00
Your Search is Over! Now You know where to get them!
See the Thread 'RobertShaw Thermostat' on this Forum, to see pictures. And search Ebay for '351C Thermostat', and Please see My feedback. Customers are very Happy with these Products.
OR Contact Us at: pantera1974@verizon.net
Thank-You
  • bundl_002
...We Machine the Copper Skirts, with the Diameter and Length to with-in .001", To the Original. I Machine the 'Skirt' in a Thicker, Pure Copper, Always Better than the Original. They are Custom Fitted to My Brass Restrictor Plates, for a More Complete Closing-Off of the By-Pass Orifice.
The Skirts are absolutely compatible with ALL Originally Installed Factory Restrictor Plates.
I Install the Skirts onto a Robertshaw 330-xxx Thermostat, Creating a 333-xxx Stat Specifically for, and Only For the 351 Cleveland Block.
I give You a Choice of 3 Temperatures, 160F, 180F(the Default), and 195F Degrees. The 160F and 195F Thermostats, with the Copper Skirt Installed; have Never existed before Now.
You may purchase these on Ebay, or at:
They cost $47.99 ea. with the S&H $5.00
Sales have been brisk, I've sold-out three times. I Don't Known if I have Heard from any of You Guys (Gals), Yet.
These will be Created and Shipped all Around the World, for as Long as My Supplier can Supply Me. Look for these Thermostats in a 'Bundle' with One 'Brass Restrictor Plate', on Ebay. And save Money.
Good-Luck with It!
Marlin
