A few items left over now my car is on the road.
A pair of used door seals. These were new but when I had my door panels retrimmed I found I needed to really push the door seals into the door opening. As a result these seals are ~1" too short, I did not use the 90 degree corner piece, just tapered ends, so using that piece they might fit you car.
Also a pair of top of the door seals. I fitted these to my car but the angle did not seem correct at the top of the door so I replaced them with different seals from another vendor. All 4 items about 2 years old, $20 + shipping.
Also the rubber engine mount kit for both sides. Lightly used, like new, 4 rubber insulators, 2 bolts, spacers, washers and lock nuts. $30 + shipping.
