IIRC, GP suggests a 6000 rpm top end for dependable performance from a Duraspark distributor.
Curious what other owners' experiences are.
quote:Rocky. Don't rev this thing to 7,200 backing it out of the garage, ok?
quote:Originally posted by Rocky:quote:Rocky. Don't rev this thing to 7,200 backing it out of the garage, ok?
Doug - Good advice!
I will second Doug's comments on the availability of the Red (Duraspark I) modules. They are harder to find.
So Doug -
Are you saying the advance plate mechanism that is connected to the vacuum canister in the Ford Distributor vibrates, or something, and affects the BASIC timing of the system at high RPM?
I can see that a person could remove the linkage to the canister easily, but isn't the pickup mounted to that plate?
How would one then fix the plate in place?
Thanks -
