Originally posted by tajon:
Interesting. I was thinking of covering the firewall, floor and tunnel. Is it not worth the effort?
When I did the bulkhead I did a bunch of research on all sorts of sound/insulation products. If I was going to do the whole interior I would probably use Lizard Skin. IIRC they sell either sound deadening or temperature products, but I do believe they do both functions. It is so much lighter then the matting products, so saving weight would be good too.
Now if it is worth the effort. I don't know. I was hoping for a lot better results from lining the bulkhead, I even applied aluminum tape to the joints, heated the sheets with a temp gun, and used a roller to make it "bite" the bulkhead as tight as I could......
Jeff
Here is
Lizard Skin's website.
