I just thought I would pass on something interesting I am working on. It seems some times nothing is ever easy. The electric power steering pump tank I am using has a plastic tank. The return line is right in a bulkhead. I tried plugging it and adding a different return port but it was a half ass job and decided to do it right.
I pulled the tank and made a new tank form aluminum with the return line in the correct spot:
Gary, It is simply fun watching you be creative. You operate at a higher level. I love it.
BTW, I was at an autoparts store in Houston, TX buying a part for my Pantera. The counter guy tells me that he is restoring an MG and knows a guy with an MG and a Pantera. I said "Gary" and he replied, "yeah, that's his name. He is on the internet". Your famous!
MGOC which is set up for an MGB:
https://www.mgocspares.co.uk/a...__CONV__MGB__47.html
There was a LOT of work to make this work; more then I would recommend. The front was modified to make the rack fit. A frame was made to mount the rack which is also a frame stiffener.
A special mount was made for the electric pump to push it up where most put the battery drop down box. I have posted this before but I spent a great amount of time re-working the rack to the proper width and brought bump steer to ZERO:
http://www.rc-tech.net/pantera1/frontsus/sus.htm
http://www.rc-tech.net/pantera1/bump/bump.htm
Now that it's done, it is pretty cool but it was a long road to get here. Advantages of the electric pump is that it can be turned on and off.
