I am FINALLY close to firing my rebuilt engine. All I have left to do is add some 93 octane gas and fill the cooling system.
before connecting the plug wires I wanted to roll the engine over to make sure the starter would engage properly. It did and the engine turned over but it was really struggling. The engine has always done that (even before re-build). I think the engine was around 10.5 to one before the rebuild and it will be in that same ball park now. I was using the orignal starter so I went to NAPA and purchased a new starter. Same results. turns over real hard. But this time it turns over (barely) and then....smoke. I am not sure exactly where because I was in the cabin looking through the rear window/rear panel. I noticed in my zeal to turn the engine over I forgot the ground strap. Could this be the source? The starter/engine not being properly grounded? Or are there other places I should look?
Anson
