I’m looking to order one of these cams from bullet cams. I'm just not sure which one. I have an M-Code 351C 4v. I will be installing camshaft, BT intake manifold, Duraspark distributor, Efi, 3.5-3.89 gears (still deciding), and a 5 speed transmission. I use the car for car shows and weekend drives with the kids.
I’m kind of leaning towards the 276°/288°. It seems to be a hotter cam when comparing it to other cams on the market with similar specs. But then again, what do I know???
What are the cams capable of? Rpm performance range? Rough idle? More torque at lower rpm or high? Any info like would be great? Any information and advice is greatly appreciated.
CAMSHAFT SPEC (114° LSA)
276°/280° duration @ 0.006
114° LSA
50° overlap
Indexed +6° (advanced)
108° / 120° lobe centerlines
EVO = 80° BBDC
IVO = 30° BTDC
EVC = 20° ATDC
IVC = 66° ABDC.
CAMSHAFT SPEC (112° LSA)
276°/288° duration @ 0.006
112° LSA
58° overlap
Indexed +4° (advanced)
108° / 116° lobe centerlines
EVO = 80° BBDC
IVO = 30° BTDC
EVC = 28° ATDC
IVC = 66° ABDC.
  • mceclip0
