I had the half shafts zinc plated and now they don't wish to slide together. At least they look pretty. I thought I could easily force the issue to an approximate length, bolt them in place and let the weight of the car wear them to a happy marriage. However, they are resisting reasonable efforts too slide the splines together. I have the splines correctly matched and the arrows aligned.
I hate the idea of sand blasting the splines to knock of the zinc.
Has anyone else faced this issue and find a reasonable solution. I am considering using my hydraulic press...
