I don't need the tool, but rather the actual plug,
On Wednesday, February 26, 2025 at 12:31:52 PM EST, The De Tomaso Forums <alerts@crowdstack.com> wrote:
[New Reply] Wanted ZF oil fill plug.
| == To reply by email, write above this line. == |
New Reply By lf-tp2511
| Wanted ZF oil fill plug.Reply by lf-tp2511
What you need is a 17 mm socket, which is the same used on VW cars and readily available at your local auto supply store.
This post contains 1 image.
[ View Reply ]
You received this based on your notification settings. You can adjust your settings or unsubscribe anytime.
