Last year I gave away 2 sets of headlight trims. I just found out that a friend (not on the forums) is in need of a set. Does anyone have a set they would part with? Will
I am currently in the process of converting to the SACC Restorations Quad Headlight system http://www.saccrestorations.net/dphl71000.html Therefore, I will be selling the headlight buckets, trim rings gaskets etc. Please PM me if interested.
BTW, great kit that is fairly easy to install. I will post picts when its done.
Originally posted by 4NHOTROD: Last year I gave away 2 sets of headlight trims. I just found out that a friend (not on the forums) is in need of a set. Does anyone have a set they would part with? Will
Will, are you talking about headlight trim rings or the fillers for round headlights like these?
