Lately I've been frustrated by the car not wanting to re-start after going for a run and then sitting for an hour or two. The only way to get her going again is to push down the go pedal and crank for 3-5 seconds like she's flooded.
So, I took her to a mechanic who has an excellent reputation with the classic mustang guys in my area and when we shut her off and took of the air filter, fuel was shooting out of the air bleeders and after a while we spotted some dripping out the sides of the carb onto the intake, so she was definitely flooding from all of the heat (the fact that the fuel line is currently routed over the top of the intake and next to the valve cover is probably a contributing factor).
So, here's what we're (well, mostly him, with my wallet playing a supporting role) looking at doing over the next few days ...
1) New braided fuel line with insulating wrap running alongside the gas tank, across the engine bay brace and then up to the carb - I hope this doesn't look ugly, but hey, I'd rather lose a few beauty points and save the engine long-term from cylinder wash
2) Block off the exhaust cross over on the intake to reduce heat under the carb (I've read mixed reviews on this one - I don't drive her in the winter, just the warm days April through November)
3) Install a 1" riser under the carb - and a smaller diameter but taller air filter
4) New fuel pump
5) New plugs - gapped to between .45 and .50
So, are we on the right track here, anything more (or less) we should be doing in this situation?
(not sure if any of this matters, but she has the factory fuel pump just now, a Holley 750 HP Pro double pumper with mechanical secondaries, Edelbrock performer intake, and MSD ignition)
Thanks!
...Some Mechanic!! You Have a Float Problem, a Fuel Pressure Problem, And BAD Needles and SEATS!! And the 'Leaking out of the Sides', indicates Worn Throttle Shaft Bores; which Constitutes a Vacuum Leak! The 1" Riser will Help, After the preceding is Fixed! Make Sure it's Made out of 'Phenelic', NOT Aluminum!
Thank-You!
I am not the mechanical expert here. But others on this forum like Marlin and Mike are. My little bit of knowledge thinks that what you are doing will not solve your problem.
The factory metal line is run over the intake and up to the carb. Also the factory set up had no carb spacer. The heat crossover as Mike said should also not be your problem. All of the things you are talking about doing are great and may even tweak an extra HP or two, but would not combine to have the issue as you describe it.
I am running a Speed Demon on a Performer (with the passage un blocked & no spacer) and do not have your problem. It sounds more like a carburetor that needs re building or replacement.
Get a new carb or rebuild that one.
Make sure you install a fuel pressure gauge to see where you're at. My engine builder advised .035 as a gap but I've read many are running .050. I run .035.
Get an air cleaner with the filter on the top as well as the sides for less restriction.
750dp may be a little big for your motor. What are the specs? There are many on-line calculators as well.
Will
My bad - You're all dead on about the Carb, I completely missed that in my post. The first thing he was doing this evening after I left the car was pulling the carb to work on it and doing a rebuild to whatever extent is necessary. He hit most of the items on Marlin's list including the spacer not being aluminum.
I'll talk to him tomorrow about leaving the cross over open, with all of the other changes, if we leave that alone it may be enough to solve the problems without creating new issues.
No, probably it is not. Look at the photo below of the rubber fuel line routing in 2511. I think that is exactly how yours is running, from your description. I have zero hot fuel issues. Like Marlin, I live in Central CA where it is HOT in the summer. If that routing was an issue, it would surely be an issue here.
Yes, it will be ugly. And not necessary.
Ford designed the Cleveland with that cross over. They never updated the design as a result of heat problems from it. Blocking it off may lower the carb and fuel temps a bit, but in itself that cross over is not your problem.
Yes, but like Marlin said, use anything but a metal riser.
New fuel pump
Can't hurt. But what you really might benefit from is a fuel pressure regulator. Holley suggests 4.5 to 6.5 psi.
Gap seems large. WHAT plugs? DO NOT use platinum; they foul easily with carbed engines.
  • Picture_3
Here's a shot of my current fuel line routing, yes, very similar to yours Larry.
I have Motorcraft ASF 52C plugs with a gap of .48 just now ... the gap of .45-.50 has been recommended in a number of posts when using MSD systems, it seems to be working fine.
Thanks for the feedback so far guys, sounds like we're doing some good things (focus on the carb and adding the riser), but overkill with some other things (blocking the cross over, and major re-route of the fuel line). She's due fresh plugs, and a fresh fuel pump is good insurance for the long road trip I'm heading on - I'll hang onto the old one as a backup.
... I've resigned myself to losing the engine cover when the riser and new air filter go on ...
  • P1140685_(816_x_612)
Do you have a dropped base for the air cleaner?
With my dropped base, I have room for a 3" tall filter, 14" diameter.
As for the spacer, if retaining the engine cover is important to you (I know it is for me) I would hold off on installing the spacer until after you've run with the reworked carb. I suspect it is a lot, if not most, of your problems.
No sense trying ALL the steps if you can find solution with just some of them.
Only the slightest of drops in the base - I'll check into a bigger drop at the local speed & custom shop ... having the engine cover on isn't critical to me, but the option is and, I'd rather see something other than an air cleaner in my rear view mirror.
As for the spacer, I've seen enough positive comments about them that I'm game to try it along with the rework being done on the carb.
Sage advice I'll nix a couple of the planned items and keep the focus, time, and money on the carb. However, having just discovered the fuel leak and with a big road trip coming up, I need to be sure this is solved in the next couple of days so that I don't glance back and see flames Eeker
Another thing to consider is new Holley carbs are not that expensive and it might be smarter just to buy a new carb. The 650 cost a bit more than the 750. By the time you pay for a rebuild kit and the mechanic’s time a new one starts looking like a smarter move. Depending on the age of your carb a kit might not fix some of the problems you might have.
It looks like you have a Holley fuel manifold and if that is the case you can turn it around and connect the fuel line from the front of the engine. Take a look at this link http://www.panteraplace.com/page225.htm
Mike
I know what you mean, but to replace this carb-for-carb would be around $900-1K US w tax & shipping (haven't found one at a Canadian vendor yet, still looking), I could go with the 'street' version from Holley and get it for around $600CDN on sale just now. Or the rebuild for $3-400 including some of the above work or a grand including all of the work.
Another option is going with an aluminum Holley 670 Street Avenger for around $530, or an Edelbrock Thunder AVS 650 for $450 (I hope I'm not in danger of starting a debate by mentioning Holley and Edelbrock in the same sentence). If I were to consider one of these carbs, then yes, definitely a better option than a rebuild, but to stay with what I have, the rebuild is more economical - if it doesn't start leaking again for a long time.
... Some folks have asked about the age of the carb, I checked the previous owner's for-sale ad, and he said it was a new carb during his rebuild, based on what I learned while I was buying the car and how long I've owned it, that means the carb could be anywhere from 4-9 years old. However, his resto took 5 years, so I prefer to think he bought the carb at the end of the resto (making it 4 years old) rather than at the beginning and it sat in the box the whole time. So, it would only have 4 years of light use (with about 5-6 months of storage per year each of those years as we both live in northern climates).
You posted that earlier.
Where out the sides?
From the fuel bowl gaskets? Easy fix.
From the throttle plate shaft? Hard fix. That would mean worn metal and only repairable with major repair, involving machining to install some bushings to return things to a proper i.d. for the shaft.
I have run 2511 with the 670 Street Avenger since I bought it. Over 35,000 miles and 7 years. I'm still pleased with the performance.
Here's a shot of where it's leaking on the driver's side, it seeps out and drips off the spring onto the intake.
I haven't spotted where the leak is on the passenger side yet, I know it's there, there's staining on the intake, may just be a slow seep through a gasket after she's sat flooded for a while.
  • 4150_Leak
I'm going to visit the shop at lunch hour today to see how things are going, I'll bring the camera and get a few shots - maybe the staining on the carb will give some clues as to the source of the leak(s). I'm hopeful that it is just gaskets and a mild rebuild is all she needs along with a few tweaks.
...Did I Not already suggest; the Throttle Shaft Bores were Worn?? BUT, They will NOT Leak While the Engine is Running, Because it is the Source of a Vacuum Leak!
One More Thing! I would Not mount that 'Steel Can' Fuel Filter right there, Behind and Between the Heads! Those Heads are 800-900 Degrees F! Perhaps even Higher! Anybody have a IR Thermometer, who can verify this? Shut the Engine off when Hot, right after a LONG Drive; and go back there and try to wrap Your hand around that Can Filter; You'll realize exactly what I mean! It IS a HEATSINK, and it delivers that heat into the Fuel. Think of how many Cubic Inches that can holds! Your Boiling the Gasoline!! I use to Have the Exact same Filter, I mounted it UP in the Decklid Opening, in the Cool Breeze! You should wonder why Racers use a 'Cool Can' to keep the Fuel Cold! To Me; it is Very Important WHERE You Install The Fuel Filter! If I wanted the Fuel Real Cold I would mount that Filter in a Bucket of ICE!! Right now I use -8 AeroQuip Hoses with a Much Smaller 40 Micron Filter, and that thing is Mounted, over the Fuel Tank, on the Pressure Side of Delivery!
I Don't 'Give a Crap' what might look Ugly!! I Want MY Pantera to look as if it Just Came Off the 'Battlefield', Victorious!!
You ARE correct to have the filter on the 'Pressure' side of the fuel delivery! To have put it Before the Pump, on the 'Suction Side' would, without a Doubt in My mind, cause 'Vapor Lock'!!
But You ARE causing that by Boiling the Fuel in that Steel Boiler You have rigged-up!
Thank-You!
An isulated carb spacer is a greate idea. When I first go my car 27years ago, I had the same issue with hard starting during the summer in San Francisco. After a run, I tried to restart the car after a short rest. At one instance, the primary float stuck open and my engine flooded with fuel coming out of the vents as I tried to crank the engine over. After I rebuilt my carb, I did a test run then tried to restart after a short stop a rest stop off HWY280. Same hard starting problem like it's flooded. I openned the decklid to check what was going on and heard what sounded like percolating coming from the carb. I tried to touch the carb and it was too hot to touch. My friend said our engines don't have the benefit of having enough air rushing through to cool the top like front-engined cars. He suggested putting a heat sink or an insulated carb spacer. After I did that, I have not had this problem.
Good luck with your issue.
The last time I point an IR meter, shooting the back of the steel heads I had at the time, they were around 190-195 degrees F(but this was with the engine running).
...You know what solved the 'Hot Soak', Hard Starting; for Me, Forever??
I got rid of the Ignition Switch, wired in a 'Continous Duty' Solenoid Controlled By a 'Round Key' 3 Position Switch (OFF-Accessories-Unilite Brain 12 Volts(On a 270 OHM Resister to supply 7.5 Volts to the Brain Only)). Then a 'Push-Button' Starter Switch Off the Acc.! But, like the Racers; I also wired the Hot 12 Volts + side of the Coil through a 40 Amp Relay, contolled by a seperate Toggle Switch!
Yes! It takes Both hands to Start My Engine, But instead of It Trying to Start Slowly, 'Fighting' against Itself...It Spins Over at High Rpm, a Split Second Later, I Hit the Toggle Switch, Turning ON the Spark, and the Explosions Begin! Absolutely Perfect and FailSafe!! And Another Great 'Theft Deterrent', except, Now, I've told all of You!
As far as My Carbs. I have NO Fuel Issues!! With Dual Quads, I can shut the Engine Off and I defy anyone to even get a whif of Gasoline! NO Noises, Nothing! Maybe a slight tick from the Exhaust Pipes Cooling Down!
...I really Do find that hard to Believe! Your telling Me that Your heads are at the same Temperature as the Coolant!? That would mean a 100% Heat exchange! Impossible! I'll Have to verify that for myself. But Thanks!
No ... as important as 'hands-on' learning is, I think I'll take you at your word that it is hot and badly placed ... I've felt the rubber hose, it's hot enough Wink your point is well taken
We've got the Phenolic spacer along with new braided lines (plus extra insulated wrap) that will sit 3" higher above the intake - rather than meandering around the engine bay - a new and smaller fuel filter that will also sit much higher along with the smaller diameter but taller air filter and a variety of heat shields and spacers to make my back pocket lighter - I don't think it's going to win any beauty awards, but if this stops the fuel from boiling, then that's one major gremlin eliminated.
Inspecting the carb more closely, it looks like the fuel was shooting out of the bleeds so high that while most of it was dropping into the bowls, some of it fell forward and collected along the edge of air filter pan and seeped down the outside of the carb onto the intake on the passenger side as well as on the drivers side ... the internal flooding was then causing the slow trickle through the secondary throttle shaft ... it's a theory - the analysis continues.
[/QUOTE]
...I really Do find that hard to Believe! Your telling Me that Your heads are at the same Temperature as the Coolant!? That would mean a 100% Heat exchange! Impossible! I'll Have to verify that for myself. But Thanks![/QUOTE]
Uhhhhmm! Okay.... As a disclaimer - I never checked what my temp gauge showed when I was playing with my highly accurate, super duper, handy dandy, Harbor Freight purchased 'Cen-Tech' IR meter (read 'cheap'). Your results may vary. I doubt the heads will read 800 to 900 degrees F though. I'll try to do a test next week when I get a chance.
Picture of my highly accurate meter (LOL).
Sounds to me like it's not about heat or worn axles, simply a fuel leak. I'd pop in new hi-perf (they have another material or size of the tip) fuel needle and seat. If they work properly and there's no dirt in them (do you have a good fuel filter?), fuel won't flow out anywhere regardless of how hot it gets...
A very powerful fuel pump may overcome any marginal needle and seat, so a fuel pressure regulator might be a good idea.
The highest temperature I've seen on an air-cooled cylinder head (Lycoming IO-540) is 450 degrees F. This was on a VERY hot day on climb-out. I would think that air-cooled cylinders would reach much higher temperatures than liquid cooled.
Dupli-Color® Engine Enamel w/ Ceramic Resists temperatures up to 500 degrees F. One would think that if the cylinder-heads reached 800 to 900 F the paint would burn off pretty quickly.
AutoMeter cylinder head gauges for liquid cooled engines top out at 340 F., however, VDO has some that go up to 600 F. for Air Cooled engines.
I just can't see a liquid cooled cylinder head reaching 800-900 F or higher on shutdown.
Well, I won't have any updates until after the weekend now :-(
Parts were in late yesterday, so they didn't really get into it until today hopefully everything will be buttoned up early Monday and ready for a road test.
For everyone else, you've got the weekend to enjoy your cats, get out there and have some fun!
Agreed. For instance, oil combusts at a lower temperature, and valve stem seals melt (teflon at only 250F). On air-cooled aluminum-head Corvairs, the stock cylinder head temp gauge once showed 510F after a broken fan belt on the road. On teardown a week later, valve seats were beginning to move and the cylinder to barrel register surface had softened & receded, slacking off the head torque so a gasket was ready to blow...
Tentatively ALL BETTER!
Aluminum heat shield, 1" phenolic spacer, braided line and insulated wrap (running along the top of the valve cover with a bracket to hold it up and away from some of the heat), new oval air cleaner since the increase in height puts it slightly above the height of the deck, new plugs, timing adjusted, and new heater hose.
She was warm when I picked her up but no problem starting. Took her for a good run in mixed traffic (a fair bit stop and go) and the temp guage was steady at 180. When I parked, I pulled the air cleaner and not a drop of fuel came out of the bleeders, she just sat there quietly. I grabbed the IR gun and the top of the carb read 130, the heads were 220, the secondary temperature gauge crept up slowly toward 200 as the block cooled down, no fuel leaking from anywhere on the carb.
She'll need a few more good runs, but based on what I've seen so far, it looks like she may be fixed.
Unfortunately I don't have a break down of what he did with the carb. the next time I talk with him I'll get further into it, but I only had a few minutes to talk, pay the bill and get the car home today.
I have to say thanks to everyone for their input again, plugging the cross-over and doing the ugly fuel line routing that he had originally suggested were obviously not necessary, and would have been a waste of time, money and in the case of the cross-over, negatively impacted the handling of the car. Glad I put this out there for y'all to comment and keep me on the straight and narrow!
I'm bringing this thread back because it has become particularly relevant for me as I'm entering the first warm season with my Pantera.
Yesterday I took the car out in the warmest weather we've seen since it came into my possession. We topped out in the high 70s, a far cry from the 100+ days to come.
I ran some errands around town with no problems. Then left the car parked for an hour before heading home. On the way I bogged and nearly killed it a few times with acceleration. Just as I was cornerning to enter the neighborhood it died on me. I had to put the pedal to the floor and crank for a while before it would start. Once started I would have to keep the revs up to keep it from dying and even then I'd get about 100 feet before it died. Repeated this process about 10 times to make my way to the house and into my garage.
It would get harder and harder to start each time and would only do so if the pedal was on the floor. I had several large puffs of exhaust when it would finally start.
I could hear the fuel boiling before I stepped out of the car. I pulled the air cleaner to find dense vapor billowing from the vent tubes and an intermittent spray from the squirters. The liquid fuel as vaporizing as it hit the inside walls. I actuated the throttle and got the squirt I expected but then it continued to squirt after I let off the throttle.
I've got a Holman Moody intake with a Holley 750dp sitting right on top without a spacer. The fuel lines and filter have been run up along the firewall and there is some insulation between the rail and the intake where it meets the carburetor. I recently installed a Fluidyne aluminum radiator that by all accounts has been working well. No problems when I'm running around but I have noticed some 200+ temps when I'm idling or in stop and go traffic. My fans need upgrading but that's another issue. I had just come off the highway and my temp gauge had been a solid 170 the whole trip.
I've always suspected heat soak problems. My stepwise solution to the problem:
1. clean and/or replace needle and seat
2. add 1" phenolic spacer, this will require different air cleaner
3. rebuild carburetor if #1 and 2 don't fix, or
3a. replace with Demon 650
In my assessment I've got 1) a carburetor problem and 2) a heat problem and they need to be fixed in that order.
Does this sound like primarily a needle and seat issue? I'm planning on pulling them without removing the carb, any issues or concerns with that?
Any thoughts? Think I'm on the right track?
I would do the simple thing, pull the needle out, clean it, and your problems may be gone. I don't think heat has anything to do with it based on what you describe.
I'm lazy so I would never work on the carb while it was still on the engine in a Pantera, I'd take it out. Regardless:
-Hold adjusting nut with 5/8" and remove screw
-Note how high the needle is compared to the flat surface of the nut
-Use nut to unscrew needle
-Inspect and clean, replace if pitted or somethng
-Install with gaskets to same height with nut
-Install screw
-Adjust float level as usual
If it was just dirt, consider fuel filter...
Good luck
BTW, if you end up hating the Holley, I recommend a Summit carb. I've had problems with all Holleys I've owned, no problems with the two Summit carbs I've owned.
I really should have put in another update. After all that work I had done, it seemed to be running great for a while, then the problem came back in spades with it coughing and choking, billowing black smoke, and needing lots of revving to keep it alive after it had heated up.
After dropping the fuel bowls as a temporary way to get it to 'limp home' I replaced the needles and seats, brought the floats back up, and she's been running a lot better (I still haven't dialed in the idle to where it needs to be, I took it down a bit and now she is struggling with hot starts). I'll see what the new season brings when I get her out of storage in the next week or two - still waiting for the rain to wash all the salt off the roads.
Mikael, you don't think heat is an issue even though fuel is clearly boiling in the bowls? Fuel should not be boiling and the fact that it is would imply that too much heat is being absorbed at the carb. Rebuilding or replacing the carb won't make it any cooler.
#5754, sorry to hear your problem has reared its head again. I'm interested in following your progress so keep us posted.
To address the heat I've ordered a 1" phenolic spacer from Summit and a 15" oval K&N air cleaner. My current round cleaner barely fits under the rear deck lid as it is so I'm going to have to go to an oval design to accommodate the additional height. I've also ordered a Holley rebuild kit.
Gonna start with cleaning the current needle and seat and checking the floats.
Originally posted by No Quarter:
Could be boiling, it's just that overflow on a hot motor looks the same...
Except that overflow doesn't pass through the bowls on my carb. I often hear sounds from the overflow but with this most recent episode I have absolutely confirmed that there is boiling occurring in the bowls.
Assuming the fuel is in fact boiling, couldn't the spewing and sputtering occur even with a properly functioning needle and seat? As the fuel boils off in the form of vapor or pressurized squirts the floats will drop and allow the passage of more fuel. So I'm thinking that even with a functioning N&S this problem isn't going away until I reduce transfer of heat to the carburetor?
Thoughts?
And, Mikael, I agree 100% that I should start with the simple inexpensive stuff. That's why I'm starting with N&S and spacer.
