I am starting to install heater hoses and trying to figure out routing at the front of the engine.  I have seen photos of them going over and around the alternator.  Do they go behind the AC compressor?  The heater hose in the photo below is a temporary bypass hose that returns to the water pump.  Please disregard it.
3FA1C79C-8411-435C-A921-C7FC3D6671B2_1_201_a
  • 3FA1C79C-8411-435C-A921-C7FC3D6671B2_1_201_a
Thanks Chuck.
I routed the hoses around the alternator and compressor, and then behind the bracket for ac tensioner pulley.  They turned out nice.
Next I tested the heater and found a leak in the heater control valve.
D5CDEA7D-5F6C-4071-A213-0A0E7EA2C83A_1_201_a
I found the posting from LarryW that explains how to fix the valve and will likely give it a try.  Larry, is your fix still holding a seal?
https://pantera.infopop.cc/top...heater-control-valve
  • D5CDEA7D-5F6C-4071-A213-0A0E7EA2C83A_1_201_a
