This is my first manual gear car in years, and I find the clutch very hard. My leg is not 100% good, and I'd like make driving less painful. I've taken off the spring at the pedal, no big effect. There's also a firmer spring on the clutcharm in the back, can I take that off? Why is it there, I thought the spring built into the clutch would be enough? Do I risk that the clutch will start slipping?
I've also considered gearing the clutcharm, extending it, which would lead to longer clutch pedal travel.
I've also seen a clutch effort reduction kit on the web, has anybody any experience with that, looks complicated...
Roll Eyes
...the spring at the clutch slave cylinder is there to insure the slave 'Fully' returns to the 'Disengaged' position. If it does Not; then you risk the 'Throw-out-bearing' contiuously 'Riding' on the clutch fingers/diaphram, which in a short time will burn up the T.O.B. ...
As Marlin said, you need that return spring at the slave. If you have a long throw clutch slave, this will add clutch pressure. A diaphram type clutch will give you a lighter pedal over the stock 3 finger type.
The clutch effort reduction kit is very expensive and a big job to install.
I bit the bullet and have a new Centerforce clutch and regular slave waiting on my workbench.
Will
Josef from Ontario, with the blue GTS, fabricated a bracket to change the angle of the slave cylinder which significantly reduces the effort to engage the clutch. This is what you are referring to.
Maybe Mark Charlton can post some of the pics he took at Kingston of Josef's engine bay so you can see how it works.
Anyone have more information on this?
SmilerLots of Squat Thrust!
Remember Football Practice?
What really needs to be developed is a hydraulic
clutch slave and master. I can push my viper clutch in with by hand. I have a clutch effort reduction linkage setup on the Pantera that helps. But not even close to a hydraulic system. Confused
