OK, I been lowering my car and now the lowest point on the car is still 4 and 1/2 inches off the ground, but the tallest point on the car is still 44 inches. How much lower can I get the car and still drive it on the street? The next steps will be more and more costly so I need to know before I spend the money. Just how low can a Pantera go before it scrapes bottom?
#2511 sits 3 3/4" off the ground at the rear crossmember, 4 1/4" at the front valance, and is 42 1/2" tall at the roof center front, 42"" tall at the roof center rear.
245/45x16' and 335/35x17"
Rear control arms are not parallel, but the uppers are Quella's adjustable which allows suspension geometry to still be correct.
It is the very rare driveway that ever scrapes the front mini GTS spoiler and it is about 5" above the ground.
No other clearance problems at these heights.
YMMV
PT if you put four of those space saver tires on the car that will get you down pretty low.
Hall makes a driver controllable ride height suspension.
It is primaraly for raising lowered cars up to get over curbs.
What I like about the kit is that it has enough presure in it so that when you pull up to a light you can make the car jump up and down.
DeTOM, did you measure the car with a half tank of gas and enough weight to compensate for you as a driver and if you want a passenger? If not, that will make a difference. Also, I agree with George about the rear crossmember being parallel to the ground, if you are concerned with maintaining your suspension setup. I would go further and say the half shafts should be parallel as well, its all part of the suspension. Rules of thumb when I was setting up my race cars. Changing stuff gets you into changing center of gravity, roll centers, camber change etc. etc.
Changing the CG is what I am after. I would like to put most of the cars weight well below the axle centerline.
How do you guys get a jack under?
There is a crossmember for the transmission mount in the rear and there is still plent of clearance on the front on the lower frame rail seam. Yes the usual jack points are now to low for me to get my floor jack under.
That's the idea Doug. I don't have lowered floor pans and with your pedal relocation scheme you are working out for me, I won't ever need them. I figure that as long as I keep the lowest point on the car at least three inches tall I will be able to still clear dead chipmunks in the road. If I can get the car low enough I will not need a chin spoiler. I know I have cut the amount of air traveling below the car significantly and I think that is partly why the car runs a little warmer. I do know it handles realy well now. I don't even slow down for turns now. Just keep the same speed. Maybe lift the throttle a smidgeon, but hardly ever use my brakes anymore unless I am coming to a full stop. This is the way my car handled before I had to jack it clear up in the air to put them super wide wheels and tires on it. I think I have figured out a way I can keep it lowered and yet still run the super wides. I don't know yet, but will keep you posted as I figure it out.
The spacer is in. I have it at just under 2". It has a 1/8" taper to point the Master cylinder down to clear the hood.
It all seems fine.
Now, if you are going to ask me if it will work for you, I don't know. I do have 2" lowered pans, a 13" Lacarra wheel.
I don't see how the brake pedal itself can be moved left. The shaft of the pedal itself would need to be bent.
You may have to go see the plastic surgeon DT and have him alter you to fit the car. That may be easier. Tell your wife it's gonna make you prettier. She'll like the idea.
...How do you guys get a jack under?
John, the jacking pad of my aluminum "racer jack" is only 3 3/8" off the ground when the jack is collapsed. The Jack is sold at Harbor Freight for around $100, and I've seen the exact same jack, re-badged by other companies and vendors, sell for up to $400.
your friend on the DTBB
Originally posted by DeTom:
Hall also made springs that lowered the car a full inch. Have you ever had any experiance with those?
The US cars have 1 inch spacers installed under the spring that can be removed with little trama. Since your's is European market car, I don't know if you have them or not.
I personally wouldn't even remove the spacers unless you want to install off road skid plates to the car. But that's just me. Maybe you'll like the sparks at night.
Doug, the car did not come with spacers but the Hall Ultras did. These raised the car way the heck up, and the tires would still rub. SO I took those back out. A skid pad would add too much weight but at the right place, down low. I have toyed with the idea of caster wheels on the low points but if one of them froze up it could start a fire. Wink
George, thanks for the tip, I was just looking at the Summit Aluminum racer jack SUM-G1037 (3 3/4" height) for $78, thinking it was a good deal, but the Harbor Freight one sits lower still (quoted 3" on the HF site) and is on special at $69.99 Big Grin)
Furthermore for anyone considering it (or another HF purchase) go to http://ww2.harborfreightusa.com/showpage_retail.taf?pageid=214 print off the coupon and save a further 20% on any single item Big Grin Big Grin.
P.S. Be aware the coupon changes, it is not always 20%, some times $5 or 10% off entire purchase. The current 20% one is valid to April 19.
With savings $56 for an Aluminum jack has to be a giveaway.
