My engine leaks oil. It was not leaking when it sat for 1 year, but I noticed fresh oil on the floor under the front of the oil pan after driving. I have concluded that a seal somewhere besides the oil pan is the issue. What can a remove without pulling the engine out of the car. I do not see oil around the valve covers, but it might be coming from the front side near the intake manifold. It may also be coming from the intake manifold. It is definitely dripping down from the front and hitting the timing cover. After 2 weeks and 30 miles I have not lost enough oil to make a noticeable difference on the dip stick.
