Originally posted by Belgiumbarry:
i have my breather/pcv just the other sides... is this relevant ( due engine rotation and possible more suction/pressure side valve cover ? ) or no importance which side the both are mounted ???
It makes no difference which valve cover the PCV is in. It is merely a function of where the vacuum port is.
THE PCV the guy at the auto store sold me is a much smaller ball valve. He builds engines, and he came out and looked at mine. Is that OK, or does yours have a filter in it as well?
You should be OK. Mine has a wad of foam or gauze in the can that functions as an oil separator. Helps keep from sucking oil down into the manifold.
