Everything You see in the Picture (except the Schematic) Largest Block with cover, ALL fuses AND Spares, Both Brass Thumb Screws, rear rubber gasket, 2 specialized mounting screws. Great condition NO corrosion, Brass is still shiney! EXCEPT! The Long Block is slightly curved from many years of being heated! ALL the Fuses You see ARE Included! The Small 'Dual Fuse' block for the power windows, With Cover; includes Two Fuses, Thumb screw and two mounting screws. Perfect Condition! Not so much as a chip in it! I will let it All go for the first $30. and I'll ship it for FREE! If You need these Blocks You'll Never see a Better Deal! I just finished a complete Change-Over to Curcuit Breakers! The Only Way to Go! Much Better Now!
Marlin
